Need Wiring Diagram for an '08 PITBULL with EFI
PurpleDog
If you got a diagram for an '08 PITBULL for EFI system I need one. Thanks in advance!
EFI schematic dog is on here; search for it while you stand by for the intro police... don't get hung up on model, a dog is a dog, 05+ likely the same.
Nomad2day
Longhair Redneck Geek
They did not start building the EFI bikes until 2007. The 07 Bulldog was the first model made and in 08 they started with the other modules...
I have a 07 EFI schematic here... What are you checking out?
Send me your email and I will send you a PDF copy of it so you can enlarge it all you want to read it...
Nomad2day@gmail.com
Neil
Sucker
Nomad2day@gmail.com
Neil
Hi Neil, I'm new to the forum. I have a 2011 Pitbull and need a wiring diagram for it saw your post and wondered if this would work for me?
Craig Halsey
Hi Neil
I have an 07 Bulldog 117 FI. I’m have electrical issues and stumbled onto this post.
I’m hoping you still have that PDF and can send it to me too? I know this is an old post but if possible it would help me greatly!
thanks in advance
Craig Halsey
Craighalsey073@gmail.com
Craig Halsey
Turn on key and all gauges come on and the FI pump runs hit start... nothing
I’m about to just rip the entire harness and rewrite it myself without the module but I need to see what’s involved
There is a lot involved in doing that. What ever it is will be simple when we find it.
When you hit start, I'm assuming your pushing the run button first. Are you hearing a click, or nothing at all?
Lets start with a couple simple things. Check the solenoid wire on the starter, make sure it hasn't come loose. Next, take a jumper wire from the solenoid and touch it to the battery and see if it will turn over.
and get back with us.
Craig Halsey
I do appreciate your efforts in trying to help. Let me give you a bit of my own background. I am a journeyman electrician and have been working in the maintenance field for 25 years.
that being said, I’ve stood on my head and bent over backwards trying/ hoping for a simple solution. Loose corroded wire etc.
Trust me, I would have found it. I need to look at the schematic to see where volts should be, but aren’t. But I don’t have a schematic. Can you tell me where/ how I can get a schematic?
