mask
knuckle dragger
I was performing the service on my Mastiff today following the step by step instructions by Gas man. When it got time to drain the tranny oil I got only about 2 ounces out. I waited for a few minutes cause the instructions said it takes a while to drain, nothing more came out. I then poured trans oil in through the dip stick hole and watched fresh and clean oil come out the drain hole a few seconds later. My question is how much damage do you guys think has been done to the transmission, and what should I look for? I noticed that downshifting had been hard in the past couple days and neutral had been impossible to find so i cleaned and lubed the heim joints and I had not ridden since I did that other than running out today to gas up and warm the bike before the fluid changes.
