Take the axle out so it takes pressue off the adjuster set screw. With the axle removed you should be able to thread the set screw all the way in so it comes out on the axle side rather than the front side. Keep in mind that you don't need that much torque on the set screw. Only 5 ft lbs at most with axle tight.alen wrench broke off in nthe rear wheel adjuster any ideals to get it out? not my day for ajusters.:bang:
little more work but take the guard off the front pully and slide the belt off.got the axel outif i can get the belt off the pully ill be set
