It could be your drive belt yes. Might be loose. Should have 3/16"-1/4" of free play with a 10 lb gauge.I just replaced my clutch cable and now I have a chirping noise from the rear of the bike under acceleration could it be the clutch rod not adjusted right or could it be the belt not tracking true again? The bike shifts great and clutch seems to be fine, how do I check the belt?
:2thumbs:The best way to diagnois the belt. I also run mine a little looser than the manual says. I believe it cuts down on wear and it was recommended by the guy a SuperMax.try rubbing some bee's wax on the edges of the belt to see if that will quiet it down.
Yeah the manual says 3/16" I set them at 1/4" and they run nice, no problems. Anything more than that then you take a chance of braking the belt under hard louds.:2thumbs:The best way to diagnois the belt. I also run mine a little looser than the manual says. I believe it cuts down on wear and it was recommended by the guy a SuperMax.
