One of the lifter blocks broke into two pieces and fell to the bottom of the motor. I have no idea what could have caused this! Metal fatigue? So plan now is to replace both lifter blocks, new rollers and new gasket set .... any thoughts or further opinions would be appreciated. Thanks! The picture is attached.
Stacey.... you should have the .600 cam as I do ... its marked on rear lobe of the cam .... whats the failure mode ?? hell i'm still thinking about that
the lifter blocks are machined from billet material and not casted ....something caused fatigue to set in and it failed ....geometry alignment dont know ???
My opinion is clean it all up check for wear score marks on bearing, bushing and mating surfaces ... make sure and check for bent pushrods (roll them on a flat surface, piece of glass) if you remove your oil pump drive gear from pinion shaft make sure the recess on the gear is facing the flywheels when re-assembling ..... if you need another cam I have a slightly used one in great condition .600
put it all together and run it.
:2thumbs:
"five"
