RRRUFF
A friend of mine has an 06k9. We have replaced his rear fender strut bolt several times. We have used the BDM recall bolts, and the most recent bolts were said to be the strongest bolts made by the bolt vendor. Here are some factors to consider.
1) Always the left rear strut bolt
2) Threaded hole in frame I had to drill and put helicoil in it, but bolt had broken a couple of times before.
3) I have checked torque specs and we are below the max torque
4) Some of the bolts have broken flush or so with the frame some down in the threaded hole and this last one broke just under the head of the bolt and just below flush in the threaded part of the hole. That's right broken in two places.
Is there anyone else out there that has had and solve this problem? Any and all ideas welcome, I have run out.:bang:
