WirePlus HELP!
bryant1609
I just started my installation of the WirePlus and have been doing a little a day. I need to know on a 2007 K9 where do you put the two main units of the WirePlus after you remove the old EHC? I was going to put it where the EHC came out but there a the ignition module for the spark plugs in in the way. If you have a K9 with the WirePlus where did you locate all the parts?
DeputyDog
Just completed the install on my 08 k-9. I was able to put all 3 new plugs in the same area as the old EHC. Tight but fit.
bryant1609
Did you leave the ignition module in the same spot? Did you have to cut or drill any holes? Please give me some details on how you got it to fit Please?
DeputyDog
Mounted the 2 new wire plus modules where the EHC was. Ran bolts through the existing holes in each and holes for old EHC. Then after connecting all the wires to the 3 new plugs, zip tied them together one on top of each other and tuck them in just above the 2 new modules. Did not relocate anything else to make room. Like I said... it was tight, but side cover just barely fit without rubbing.
bryant1609
I have it that way now with the Black unit with the wires pointing up in the back of the battery box, and the other unit with the wires facing forward in the other hole from the old EHC. But no room to put the ignition module back where it was. This is where I'm having the problem. Did you zip tie it instead of using the bolts?
