New X-Wedge Parts
Dragon42
S&S has updated their site with new performance parts for the X-wedge. They show a Big Bore kit for 128ci, a performance easy-start cam (569), and CNC ported heads. With just the cam, you bump up to 106 HP, and 126 ft/lb torque. The big bore kit just nets more torque at 140 ft/lb or so. They don't show any info on the head work.
I have the old non=compression release cams in my motor, and it starts hard! The cam upgrade seems like a no brainer. I have a set on order, and will likely have it installed before May.
chacha
Chaff Your EHC!!
Good Tip Dragon. The cam change-out looks to be pretty easy. I'm waiting to get the motor fully broke-in before I take on any motor work. Let us know how it goes....
dnespolo
I think to get that power you also have to change the programmable ECU from the fixed one that your wolf come with and the throttle body to a 58mm.
