lee
just like the prize prick learner mechanic that I am I took my wheels off for a good clean the other day without paying too much, or should I, enough, attention to the spacers. Please help. 3 spacers all different sizes. The largest I know goes between the swing arm and the hub of the wheel on the right side. That leaves 2 - one slightly smaller than the other and the smaller one has a bevelled / tapered edge. I think the smaller one with the bevelled edge goes between the brake caliper and the hub and the other between the swing arm and the brake caliper. Is this right? Also, does the bevelled edge go against the hub or the caliper? It looks to me as though the bevelled edge should slot into something, only it doesn't slot into either the hub or the caliper as it is still larger than either hole. After trying both ways the caliper does not seem centred on the brake disc, hence the wheel does not run freely. The inside pad seems a lot closer to the disc than the outside pad. I guess the pads will always rub a little but I don't know if what I now have is excessive, as again I did not see how much it dragged before I took the wheel off. I also now do not have any shims on the caliper bolts as putting them back makes the problem worse. They were on there somewhere before I took the wheel off. Any advice you can give would be very much appreciated as always.
Thanks
Lee
Thanks
Lee
