Need a Front Master Cylinder Rebuild Kit
ahoffme
All,
I have called a few places looking for a front master cylinder rebuild kit for a 09 Coyote with no luck. Does anyone have any suggestions?
Thanks,
Aaron
Little-Boo
Call Strokers in Dallas see if Lena can hook you up if not call Performance Machine (PM) there are serveral out there that carry those parts.
Carlos :whoop:
ahoffme
I tried my local shop...Gateway Big Dog and Strokers...both did not have any in stock and looked like non on the way. I'll try the others too.
RubWhore
Asshole Extraordinaire
The only thing you reely need are the cups and all I ever do is use the wons for a Harley
84 up softail reer
Ray
I rebuilt mine last year front and back and our dealer had them in stock , 2004 though.
The direct number to R&B's is 615-859-8807. I used to talk to JB but he isn't there anymore. They usually keep a lot of parts in stock , but who knows now. They still have several bikes too.
Tell the lady Ray told you to call,I can't remember her name,, sorry. I was in there this afternoon.
Ray
ahoffme
Well..I've called everyone that was recommended with no luck so far...i think i will try the HD parts and see what how that works...i think i just have a bad o-ring as it is spitting some fluid on me. Thanks Guys.
RubWhore
Why do yu think I told you the route to go as bigdog haint had any for a while
ahoffme
UPDATED: Master Cylinder Rebuild
So i got the harley rebuild kit and installed....leak is gone but, i do not have much presure in the break line (very weak front breaks)...any suggestions? We tried and tried to bleed the air out of the line and fluid seems to be flowing good. Did you use the whole rebuild kit...or only the cups and o-ring? The harley piston is shorter but has a longer spring (which i thought would even it out)...is this my problem? should i use the existing plastic big dog piston and only use the new harley cups and o-ring???? any help would be great...it is riding season now and i am parked with out breaks....thanks...
RubWhore
You should have only used the cups and O ring but it will wurk you may still have air I always just change cups
