Twin Suckers or Dual Runners
bryant1609
I'm about thru with the RAM EFFECT of my DM forward facing Skipe air intake was was thinking about getting one of these Intakes in replacement of it. I've been looking at the Arlen Ness Twin Suckers because not as many people have them as the S&S Dual Runners. Your opinion of these two Intakes would be very helpful, the DM Skipe is GOING no matter what!
bryant1609
I cut off the filter flange and put a big k&n on the tube. So far so good.
Hmmm, that would save some money, but kill the DM Skipe if I wanted to sell it. Thanks, good idea, but I'm still thinking to go with one of these two and sell the DM to someone.
RCAdd1ct
JAFO
Ok.
Talking out loud here.
You are going to buy something new and sell your old one. Will the delta be less that $50?
Been there, done that. Not going to happen.
Now if you want a different look, cool, but look at the above before you do it for monetary reasons.
bryant1609
Ok.
Thanks for the feed back but in this case I really don't case if I can or cannot sell the DM Skipe. The main thing is to get rid of the RAM AIR EFFECT. I really don't want to cut it up in case I can sell it.
moedog
RFFR
i"ve got a spike mounted vertical and have had no prob with the ram effect. have you tried vert or not like the look?
aspen874
I had the D&M spike and problems with it cruising around 70 mph, tried different jetting but never seem to help. I switched to the S&S dual runner which solved all my issues.
aspen874
I have 34-80 put in when they dynoed it, but i also have a xxx carb along with thunder heart ignition and V&H big radius pipes. my dyno were 108hp and 124 lbs torque with my setup
