key on an nothing happens
dutchess
turn key on an nothing happens at all can any 1 tell how to fix this problem asap its 2002 pitbull instructions an images would be great
thanx
vicki
kiwi
battery fully charged ? are all the connection tight and not corroded, are you getting any lights?
First off did this just happen or did you do something to the bike and then it started? I would first suspect if you had something apart then you didn't put it back together properly. Check to make sure you didn't miss a connection on one of the battery terminals.
If it just all of a sudden started doing this then I would suspect the battery or maybe a bad ignition switch as stated above.
Five Five
Vicki .... I agree with Rays comments .... provide as much info as to what led up to the failure.
Bill
RRRUFF
Not that familiar with pre-2005s electrical, but I would start at the battery. The terminals can look clean and be tight and you still may not have a good connections. Oh and do put up some more info that was leading up to the problem.
kiwi
I talked to Vicki and her hubby last night and he said he had just come back from a test ride and when he went back to the bike there was no power or lights , he said the battery still had heaps of power so he was going to check all the connections today .
hopefully it is just a lose connection
