Winter 2010 Mods - dumb stuff I'm doing to the Ride
Looking great. I like the black tones. I like that plastic sheild you put over the backbone also.
:2thumbs:
linx
I like the primary...looks industrial looking. I dig that better than the flashy chrome lightning bolt belt driver covers, or whatever that 80's shit is.
chacha
Chaff Your EHC!!
Rainy day so time for more updates. Powdercoated most of the fuel filler --
...and I heat coated the pipes black and got 'em back on.....
And here's an image of the new fender "chick" which should be here soon (last big item to get her back on the road).....
WAY better that the old fender chick that I couldn't take anymore -- bad history. The lesson here is if you have to change artists mid-stream, you may as well reshoot all the tins -- it just won't look right otherwise.
seatmaker
With regards to the Heat Demons, where did you mount the switch? The display I saw didn't look like it would work or look good on the dog. Is there something unique made especially for the dogs? Fairless?
chacha
Chaff Your EHC!!
Heat Demon controller is mounted just ahead of the left switches...but I'm running stock HD controls on a Chubby bar.
They won't fit the stock BDM bars and wouldn't mate-up to the BDM switches anyway.
Fairless
the heat demons go inside the handle bar so you can use them with anything. you just have to get the correct clamp size to mount the heat adjust to your bars
