585 change
Trainguy
Chromeoholic
I finally settled in on move and job at Indianpolis IN.
I changed jets to .32/78 one more step to help with the lean condition after air cleaner install
Got a new lift I really like this liftView attachment 5648
makes life easier
Very cool on the bike lift. Thanks for the info early in the year went with the 585. Runnin' 33/76 ( might bump to 78)nice combo 2/1 pipes s/s cleaner:2thumbs:
stryfox
I just had my 08 mutt 117 dyno done.
Stock motor- K&N filter and opened up stock supertrapp 2 into 1 exhaust.
85 hp and 98 tq
Best guess where would the 585 put me?
erldawg
85 hp and 98 tq
Numbers seem low to me. I thought our stock 117's were up around 95+ hp correct me if I'm out to lunch here..
armad
What jetting are you running? I haven't had mine dyno'd, but just finished sealing up everything on my 2 inot 1 Supertrapp. I had an issue with whistling coming from the muffler, but fixed that with rtv sealant. I still have the inner pipe with the 2 cones. I just moved the cones farther back in the screen pipe and welded up the holes the adjustable plates used to attach too. It sounds real good, and I have very little decel pop, if any. When it is really hot out I get an ocassional hiccup through the carb when at cruising speed. Will probably change out the intermediate jet, from what I have reading on here.
stryfox
Not trying to hijack this thread.
Thoses are the numbers I got. I was a little disappointed with the hp number but it pulls good.
The af ratio is nice all the way across.
I do have decel pop so I tried adjusting af idle screw per s&s manual. Still pops. Pulled bowl and have .0295 inter and .074 main. Guessing dyno guy had good af numbers so didn't jet.
Would going up on jets increase hp and help with decel pop even though af graph is good?
V
Usually rejet with a exhaust change. If you buy the pipes fpr your bike thru big dog they usually come with a .31 intemediate and .76 or .78 main. The jets you listed are the stock jets, but that doesn't mean that they are not right. The next up from the .295 is the .31.
Also not sayin ya need to buy BD pipes.
stryfox
Tried adjustin a/f screw, When almost all the way in it dies, however I can back it all the way out (9 full turns)with no change past 4 whole turns out.
This tells me I need to go up a jet.
Runs better a 5 turns out. Any opinions if I should try a .31 or just skip to a .32?
V
Might try the .31. you should start at 1 1/2 turns out and go from there. Also might try the .76 main. You can change the main jet later if you want by just removing the bowl drain plug
Iman
went to a 585 over the summer. I can really feel the difference. HP only went up 2 points - from 96 to 98 but the torque went up from 109 to 127
V
33 intermediate
78 main
S&S Desparado with K&N Filter
Mean Mother exhaust with Thunder Monster Baffle
reloaderbmg
OLD DOG
guys, good thread on cams & all that goes with them.
just thinking, what cam came with an early 07 k9?
have s&s tops with roller rockers & red paint springs!
s&s 585 sounds good
stryfox
s&s 585 sounds good
I'm not 100% sure but if you have the red stripe springs and roller rockers you should be able to go with the .600 cam
In 08 they went to smaller springs only rated for 585 and stamped rockers and an even smaller cam.
Hope this helps.
Don't take my word for it, ask around.
