engine specs.
05 old dog
i have an 05 bulldog...new to me. is there a place to check engine specs...cam lift...valve size in heads comp ratio and such to see just what ive got and what mods i need to consider...i know its the engine that was epa compliant.
V
If its stock
S&S E carb
9.6/1 Compression (i think)
Comp cams .569 cam.
Comp cam valve springs
Hydralic lifters
TP rocker boxes
4 3/8 stroke
4 1/8 bore
Valves may be a bit smaller than stock 117
Cylinders are .040 taller than stock to reduce compression ratio from original 10.2/1
Non adjust able crank trigger fire igntion
Make corrections and additons as required :D
don't forget that along with the E carb there were also restricter plates between the intake and the jugs. these can be removed/ modified for better A/F flow.
05 old dog
yes...ive removed the restrictor plates and rejetted for the V&H 2into2 pipes...got a S&S dual K&N airfilter commin...i like the E carb but am wondering if the XXX G would make a difference considering the small valve heads.....any thoughts?
lee
the triple x G is quite a big carb that will flow a lot of air (higher top end hp) but at the expense of air velocity (sacrifice on the lower end). Small valves kind of do the opposite. If you want the top end and go XXX G you may as well get the larger valves as well. Its all about matching up the components
