ezrizer
Hello from South Louisiana, great forum and thanks for all of the help and good advise. I'm looking for a K&N filter to replace the stock S&S for my 2004 107. I've seen a lot or suggestions to use the 3226 on newer bikes however that one measures 6x4-5/8x2-1/2. There's also a common suggestion to grind off the rear tab so the filter fits properly. My exisitng S&S filter measures 6-3/8x5x2-1/2. I found a K&N 3260 which measures exactly those dimensions and wouldn't require grinding the tab. Is the 2004 air cleaner different than newer bikes or is there any reason I shouldn't use the 3260 which seems to be a much better fit?
