Thanks Eric.....3psi is way to low to signal a warning.....Is there other sending units with higher pressure ratings ?low oil pressure.. usually below 3psi.....
Hey Five dont get upset by what you see for oil preasure cause our motors dont run much.. I played with oil pump spacing to raise the preasure with good results but at idle it will scare you lookin at a guage but all is wellThanks...Eric / Rub....Goin to install a pressure gage and continue to run the idiot light for the hell of it.....but i'm going to run my pressure gage at the tappet screen location just remove the screw and install....figured thats a good place to get a good readin on whats being pumped to the top end...
Thanks
:2thumbs:
"Five"
Yea figured that.....just want to establish base line on the pressure readings....so I know what the norm is for our S&S motors....just did a complete overhaul on my motor and waitin on my crank to come back after balancing.....I want to do a little more monitoring on this motor.....My front rod bearing went out at 28K just want to make sure my fresh motor has plenty of oil moving aroundHey Five dont get upset by what you see for oil preasure cause our motors dont run much.. I played with oil pump spacing to raise the preasure with good results but at idle it will scare you lookin at a guage but all is well
:up::up::up:
