narow37
Angry Southern White Man
hey everyone,
I'm having a little trouble with my trans. Shifting from 3rd to 4th will miss sometimes and 3rd to 2nd will take a few tries and then will be a solid "clunk" engagement. all other gears shift fine to and from and neutral isn't a problem to find. the trans has redline heavy shockproof in it. I think that the shifter pawl needs adjusting but wanted to get your opinions and if you think that is the case, what is the easiest way to adjust the shifter pawl. the service manual says to remove the top trans cover and the adjuster is on the left side of the trans. keep in mind this is a K9 and removing the top cover means at the very least removing the rear exhaust, right side battery cover, and the adjuster screw doesnt have a lot of room requiring a ground down allen wrench. If you have any tips please pass them along. Also, I know its not the heim joints because I cleaned and lubed them and I can recreate the problem with the bike on the stand and just moving the tire and shifting by hand.
