Passenger pegs
popsicle069
Has anyone found different passenger pegs, or found a way to relocate the pegs to give the passenger a better ride?
My wife is used to riding on the back of the Road King and able to move her feet around quite a bit. We went for a ride over the weekend and she says that her knees were cramping due to not being able to move her feet and that her knees were up too high.
Thanks
Rich
My wife says the same thing. Kuryakyn makes a clevis adapter that will fit bigdogs. Then you can put anything you want on there. I'm working on getting something for her now.
BadBrad
2005 Pitbull
Thanks
Rich
It may be easier to just trade her in for someone shorter. :cheers::whoop::cheers:
KLRDOG
I changed out the stock pipes on my 08 ridgeback and used the exhaust mounting bracket in the right rear to mount a peg on and then put a peg on the oppsite side on the top kick stand mounting hole. Works fine. :)
Kdub
I swapped the right peg for the left and left to the right. Doesn't give more room but it makes the flat part of the peg angle up towards the passenger this way she can push back with her feet instead of having them slip forward.
Moespeeds
If you snoop around someone makes a set of adjustable mounts. You can swivel them to raise or lower the pegs about 2".
