I'm getting ready to install some John Sachs heads, 600 cam
Does anyone have a similar set up on a 06 and newer bike that hasn't had a clutch issue after the install?
I read all threads with the problems on the older bikes
Thanks
John Sachs did my heads, big valves, decked heads, cut jugs and I run a 656 lift red shift cam 11:1 compression or so and have a stock clutch in it that holds. I have destroyed 5 tires, 3 transmissions but the clutch is holding. I make close to 150 tq and up above 130 hp......Other goodies in the heads and a R&B 2-1 pipe.... Converted to wide band fuel system..
The tire and transmission is my weak link.....
My wrist is fine though..
Yes a clutch I need when I am at the track making numerous runs and it starts to fail when it is hot but not on the street.
Got 4 degree dogs in the transmission to hold it in gear
Neil
