Skull Headlight
Splitlog
Has anyone installed or know anything about the solid aluminum life size skull headlights?
I have seen them. a bunch for sale on e-bay..In person they look like good qaulity as far as the metal itself. not sure about the electricall etc...
Just throwing around the idea of putting one on my bike but would like to know if any of you know more than I do about them..
Thanks in advance
:confused:
avdhunter
I had a JBS engineering on my 04. Easy install.. causes no problems... only draw back is the low beam is not very bright and the angle dif between low and high beam is considerable. I replaced my front turn signals with a set of Silver Bullet Halogens wired direct to battery with fuse and toggle. Not quite LIFE size as BB said! Here is sum pics!
Headlight:
Matching Breather:
1ezrider
Is this the same skull headlight being offerred by "Realheadlight" out of Stone Mtn Georgia? or are they different? Love the look, would really like to have one on my K9
isalas
Anyone that has one of this installed know what the ohm should be on that 20w resistor? I purchased one of the skulls a few days ago and currently trying to get it installed without the resistor melting away the relays, I called headwings and they said they will get back to me on that...
peteyunit
I have one and LOVE IT !!!
I got mine through an outfit in Georgia, only had lites put in the eye sockets and the mouth welded shut. It is the hit of everywhere I go. Only hitch is that it will not operate using the wiring to your existing headlite. I simply ran a wire and separate on/off switch from the battery to the headlite and it works great. I ended up drilling in a small red lite in the rear of the skull, so I could easily tell when the lite was on. hope you like the pic
Pete
