Relic
Trying to torque the engine sprocket nut to 150 ft/lbs by my lonesome and can't hold the brake etc to get it torqued.
I've read on here you can use a 1" X 1/4" X 8" steel bar, aluminum bar or wood block to wedge between the engine sprocket and clutch sprocket.
I'm leaning to trying the wood (don't want to screw up the teeth on the sprockets).
Any advise ?
Also, is everyone going with 100 ft/lbs on the clutch hub nut ?
Thanks in advance.
Any advise ?
Thanks in advance.
