No power
easy riders
Hi guys,
I,m from Curacao ( Netherlands Antilles). I was last week in Bonaire another island in the carribean for a bike week.when we where riding a tour my bike shut off no lights no power only the left rear light come up.my battery was over charge.the VR is damage.
can some one help me.
THX,
errol
BadBrad
2005 Pitbull
Hi guys,
THX,
errol
What kind of help do you need? Sounds like you already know what the problem is. The VR and Battery can be purchased from a lot of places that carry BD parts.
easy riders
Hi Brad,
I change the VR and battery but still no power, no lights nothing.
only the rear light go one.there is no lights on the EHC.
BigDogBro1
Made in the USA
It sounds like the bad VR could have caused damage to the EHC module. You could use a wiring diagram for your "07" K9 to get going. I sent you a PM (private message). If the EHC did get trashed you can either buy a replacement BDM EHC or replace it with either a Wire Plus module kit or inquire at BDM for delivery on their new EHC replacement kit due out soon.
There was a factory service bulletin on the VR. Newer ones are identified by date or somehow, can't recall now. Your "07" should be okay. Check the Technical forum service bulletins.
Not sure if the K9 has a second branch fuse somewhere. I only see the main 40A fuse or CBrkr, but you say you do get a rear light on so that fuse sounds okay.
Make sure your battery terminal wire crimps are all crimped tight on the wires. Mine worked loose and caused weird EHC like problems. Weird LED light display, engine dies, no nothing when key on.
The Wire Plus kit has been used alot here and works well. Would be my first choice if you need to go that route. It does involve some wire harness cutting and changing bike harness to new WP module connectors.
Wire Plus Module here:
http://lowdownchopshop.com/big-dog-electronics/wire-plus-big-dog-ehc-module-wp-374.html
Wire Plus Module installation instructions:
http://www.bigdogbiker.com/forums/how/7946-how-wire-plus-hand-control-module-ehc-removal.html
easy riders
thx bigdog bro1,
I have the pdf you send me.
I already order the manual, next week I should get it.
when I'm back home today I go true the diagram and let you know
thx
easy riders
rob, I have a shortstop between the VR and battery is these the circuit breaker? it measured closed, but the black switch is loose.can you tell me more about these shortstop/circuit breaker?
easy riders
another thing.I can measured between the black and red wire that go to the EHC. I think that the EHC is damage.
where can I get more info about the wireplus? they ship to the Netherlands Antilles?
BigDogBro1
Made in the USA
The info was in this earlier post down below.
Wire-Plus Big Dog EHC Module WP-374 2004-2010 Models - Low Down Chop Shop
MARV
black button is a reset
as long as you have the battery voltage on both sides of the breaker then your good
should also make sure your 'run' and 'start' switch are working
easy riders
marv, I think the reset button is broken it feel loose.
escobar I send Jake a pm, I wait for his reply.
I think the VR damage the circuit breaker, battery and the EHC.
BigDogBro1
Made in the USA
Measure voltage on both sides of the circuit breaker with the RED tester lead and connect the BLACK tester lead to GROUND on the batery. If the CB is okay then 12v should be on both terminals of the CB. The button may feel loose, they aren't made with a tight fit anyways. I'm sure it's good to go!
You could also bypass the CB with a jumper and try start up again.
You said you do get a rear light on so that CB sounds okay. It's the only way to get power through to the light.
easy riders
I think my EHC is damage, when I measure the black and red wire that go to the EHC it measure short circuit.
I order the wireplus from jake.
my dog is dead know
BigDogBro1
Made in the USA
my dog is dead know
What is the voltage across the red/black wires to the EHC? It needs to be about 12.8 volts DC to work properly.
