only if your springs are not rated for that much lift...V So if I want the 600, you would suggest i change the springs
This is what the BDM Service Manual 1994 ~ 2004 says on page one."Iman"....dont mean to hijack your thread but while were on the subject of cams...does anybody know what comes standard on the
"107" S&S manual makes reference to 2 cam varations one being the "585" and the other being the "600"
My scoot is a 2003 pitbull and that 107 pulls strong from an idle too redline...
Thanks "55"
I did extensive search on this subject and if you follow knuclehead's linky above you find the results.http://www.bigdogbiker.com/forums/motor/16666-585-change.html Check out this post. I went with a Dave Mackie 580 and love it. Gobs of torque from idle to redline.
I did 585 it's the right choice for the 08' if you don't plan on doin' the springs and comp. change. You have a 546 in there right now and you will notice a big changeif you have done the exhaust and intake without a lot of expense for now:2thumbs:
IMO![]()
Yup:2thumbs:I did extensive search on this subject and if you follow knuclehead's linky above you find the results.
What it comes down to is the 08's have the lower rated valve springs and standard rocker arms. Therefore the .585 cam or similar is a good bolt in choice.
Any cam with a higher lift you'll need to raise compression, new springs, roller rockers to achieve the full performance of the cam. Assuming of course you've already changed you exhaust pipes and air filter. :zz2cents:
Thanks James....I will have to take a look at my serial numbers on the cases...good info.....what cam you running on your Pitbull ?This is what the BDM Service Manual 1994 ~ 2004 says on page one.
"107-inch S&S (Big Bore) motors are identified by the SA (Special Application) stamped near the serial number on the motor cases. S&S 107 inch motors will have either the S&S 520 or 600 camshaft installed."
"107-inch TOTAL PERFORMANCE (TP) engines have either the TP logo or Big Dog logo located near the number boss. All TP motors use the CRANE 304 camshaft." Hope this helps.
