Cam Sensor replacement
Jspeeddemon
I am attempting to replace the cam sensor, with a Harley Evo sensor, any idea on the wiring from Big Dog to the Harley GR, RED, BL wires?
you will have your positive and negative red /black wires the green or other color is the ground wire match the black to black / red to red / and the third color (ground to ground)
Hope this helps
DRBarnhart
Insert title here...
Hope this helps
I wouldn't call the green wire a "ground" as that could get confusing. The green wire supplies the signal to the ignition module so the module can remove the ground from the coil to fire the spark plugs.
To put it another way, the colors should be the same... :D
Dennis
Jspeeddemon
Matched up the colors and it worked perfect! Back on the road again, thanks to BD forums. Thanks to all the posts in the forum there is great information to do it yourself.
John
