MikeG
The Doctor
2007 K9 with V&H Big shots and factory breather. Recently purchased this way and I think its lean. I get lots of pop on decel and an occasional hicup through breather. While riding at any steady speed in any gear at 2000 -2500rpm you can feel it surging but as soon as I twist the throttle a bit it will jump and run fine. Pulled the plugs and they look right on and will go ahead and replace since i pulled them. I dropped the bowl and the jets are 74 / 295. Are those the factory sizes and it wasn't jetted when the pipes were installed by previous owner?
Anyways, I see in other posts people are running like 76/31 jets with the V&H pipes so would that put me on the right track?
Any suggestions would be greatly appreciated my fellow bikers!
He's daydreaming again wishing his bike were home so he could work on it. You may just want to start off by changing out the intermediate jet. This will require dropping the bowl on the carb to get to it. Go with a 31 or 32, then see if that fixes your hiccup. YOu can go back later and change the main just by dropping the bowl plug in the bottom of your carb if you need to change that jet.
