TCALZ06
There are only two places for the tranny fluid to go. If it was leaking you should know it.
If your trans is shot/bad seal it can go into your primary from what I've heard from guys on here.
I would probably drain your primary and try to see how much you pull out
I like Amsoil 20/50 for the engine
Harley for primary(no synthetics)
I also use Amsoil for the trans. It was mentioned above not to but I've never heard this. Also, even Baker has changed their recommendation from what I've read on here from redline shock proof to something else now
I'm a big fan of synthetics & Amsoil but if you change at the proper intervals it probably doesn't matter. There are a lot of different opinions on oils
). Therefore, my solution is to keep small piece of black paper handy. I pull dipstick then lay it on paper. Oil level then shows up. Before then, always appeared tranny was bone dry. Duh!
