BDM Parts on Backorder!
Banned
Eric, just curious, did you order your cable from Cycle City in Kingsport, Tn. on the Group Buy?
not yet.. I just want a back up... tring to support my local bussiness... I'll give them a shot 1st.. if I had to have 1 due to being down I'd get it sooner.. bikers dream are good folks. so I told them to get me 1.. even if thay go to barnett.. thanks though...
RubWhore
Asshole Extraordinaire
Just measure yours and look at any catoloug as they all show cable length ends same as harley on the throttle cables you have to change to S&S`s longer cable guide at carb cause nobody makes the cables with the right throw which is 3.5 inches and the new style ends
The Clutch cable for a K9 or Chopper is the same as a harley roadking plus 6in cause I used my extra from my roadking when I built my K9
In my conversation with Barnett last week they mentioned that they use a different/special end piece on the BD RSD bikes due to the ball and ramp assembly. Their words to me.
Hello Raymond, yes you can send it in for repair. send it to 2238 Palma DR. Ventura CA. 93003 and please specify that itsa BIG DOG clutch cable because we use a special cable end at the transmission end for their ball and ramp set up and please include return address and phone #.
Best Regards
RubWhore
Compare em they are the same I called Barnett to get throttle cables and they said they couldn`t even tak to me cause the were BigDog proprietary as I needed 8 over cause I used ridgeback pullback bars,,,and of coarse after dealing with stupid Big Dog dealers I new better than to call a stealership so i called S&S and they explained the throw issues fronm 5 in to 3.5 but I did compare the clutch cables and mine were the same but yours might be different as I built my bike from junk and you got yours new,both use the same style of ramp clamp though and work the same on the clutch end and are Identical on the handle bar side.......wunder what they thinkin the differance is???
Don't know but there have been several others here that have stated they changed the cable end due to all the breakage. I'll take pics of my re-built one compared to the current one when it comes in and post here.
