I bet jake knows ... where is he @??? something dosent sound right does it?? keep it simple.. are you sure you arnt missing a wire or something somewhere?? maybe a broken wire from the switch????/eric,i wonder what would happen if he disconected the box and turned just the key on to see if he has power.im still wondering why this happened after replacing the switch.er was the bike ok before you lost your keys?
Broken wire from the switch? Eric, remember that was the problem I had.I bet jake knows ... where is he @??? something dosent sound right does it?? keep it simple.. are you sure you arnt missing a wire or something somewhere?? maybe a broken wire from the switch????/
Here is a pic
Resistor was only for the 05's mayby early 06'sI still think that was a ehc add on resistor from bdm or something.. there is some picts here about the early ehc having something like that..
yep yours was from hand contrl switch.. he said his wont turn on anything from key switch..Broken wire from the switch? Eric, remember that was the problem I had.
I imagine but I'm not the electrician expert here. When you turn the key on do you get any lights at all? Headlight? dash lights? anything?Ray, if starter relay is bad, would that cause no power at all to the EHC?
