Oil
Slow Vince
Living a little off plumb from Main Street, must always consider what's available locally (and within a 1000 miles down the road) when the bike comes home to roost [very soon now].
Augusta GA. Dealer dinosaur juice at 500, switched to AMSOIL 20W-50 Syn at 2500 service... Plus K&P filter at that time.
Local AMSOIL distributor lives about 3 miles from me. Case of AMSOIL ~$100. Would use Mobil 1 V-Twin if I could get it without being gouged, but I but have been quoted prices in excess of $20/qt.
I'm "old school" enough to believe that new engines need some "fitting" of moving parts, but pay attention to upscale machines, e.g. 'Vettes, Beemer bikes, CVO Harleys, and others that are delivered new with synthetic oil.
For tranny, using H-D Formula Plus for tranny and primary. Checkride after 2500, shifting was smoother, but I don't have enough miles on the Harley fluids to offer an opinion over the long haul.
Also thinking about giving AMSOIL tranny/primary a try, since the test specs put it at the top of the list. Probably use it in the Harleys first, when they next come due, but would like to hear any comments from those that have used it...
K9Anniv
Redline ..all the way. Their "Shock-proof" tranny fluid (aka- the pink milk shake) really makes a HUGE difference, in my opinion.
kurtxt
Chopperman
Thanks for the great info for everyone,I have been using ansoil for 25 years in everything I own.I will not use anything else.Once you understand the about lubrication technology you will be hands down sold on the amsoil product line.Everyone out here has made a big investment in there machines now protect it with the best lubricants money can buy.
HOOLIGAN
SICK BOY
I work with a guy who is an amsoil dealer and heve been talking to him about their products. He told me he would sell me a case of it for his price (less than $100) so that's what i will be running in the S&S from now on. If it's good enough for Raywood it's good enough for me!
BadBrad
2005 Pitbull
Agree on that. Amsoil's motorcycle oil is supposed to be changed at twice the manufacturer's interval. So if you're changing it every 3,500 miles, then you're not supposed to go farther than 7,000 with Amsoil's oil and EAO filter.
Just for a little education for those who have not done much research on the oil for their expensive bikes, I've taken the time to locate this information for your reading pleasure:
Motorcycle oil tests done from an independent certified lab:
Wear Protection (4-Ball, ASTM D-4172)
The ASTM D-4172 4-Ball Wear Test is a good measure of the existence and robustness of an oil’s additive chemistry. It is used to determine an oil’s ability to minimize wear in case of metal-to-metal contact. The test consists of a steel ball that sits atop three identical balls that have been placed in a triangular pattern and restrained from moving. All four balls are immersed in the test oil, which is heated and maintained at a constant temperature. The upper ball is then rotated and forced onto the lower three balls with a load measured in kilogram-force (kgf). After a one-hour period of constant load, speed and temperature, the lower three balls are inspected at the point of contact. Any wear will appear as a single scar on each of the lower balls. The diameter of the scar is measured on each of the lower balls and the results are reported as the average of the three scars, expressed in millimeters. The lower the average scar diameter, the better the wear protection of the oil. In thiscase, the load, speed and temperature used for the test were 40 kg, 1800 RPMs and 150°C respectively.
ASTM D-4172 testing SAE 40:
Royal Purple's wear scar was 1.08.
Amsoil's was wear scar was an incredible 0.40. Royal Purple's wear scar is MORE THAN DOUBLE of Amsoil's.
When testing the SAE 50 oil:
Royal Purple's wear scar was 0.95
HD Screaming Eagle Syn3 wear scar was 0.70.
Mobil 1 V-Twin was 0.65.
Amsoil's was one of the best perfomers with 0.40.
High Temperature/High Shear Viscosity (HT/HS ASTM D-5481)
Shear stability and good high temperature viscosity are critical in motorcycle applications. How these two areas in combination affect the oil is measured using ASTM test methodology D-5481.The test measures an oil’s viscosity at high temperature under shearing forces. Shear stable oils that are able to maintain high viscosity at high temperatures perform wellin the High Temperature/High Shear Test. The test is revealing as it combines viscosity, shear stability and viscosity index. It is important because bearings require the greatest level of protection during high temperature operation. Test results areindicated in cetipoises (cP), which are units of viscosity. The higher the test result, the greater the level of protection offeredby the oil.
On the ASTM D-5481 Shear Viscosity test machine testing SAE 40 (higher is better on this test.)
Royal Purple scored a 3.94
Amsoil's was 4.52
When testing the SAE 50 group (Higher=better)
Royal Purple tested as 5.34
Screaming Eagle Syn3 as 5.45
Amsoil's was 6.02, best scores of the test.
Pennzoil and Bel-Ray EXS scored the worst of the test.
Volatility (Evaporation) (ASTM D-5800)
When oil is heated, lighter fractions in the oil volatilize (evaporate). This leads to increased oil consumption, emissions and viscosity increase. Higher operating temperatures produce greater volatility.To determine an oil’s resistance to volatility, ASTM test methodology D-5800 is used. In this test, a specific volume of oil is heated to a temperature of 250° C for a period of 60 minutes.Air is drawn through the container holding the oil sample, removing oil that has turned into vapor. At the end of the 60-minute period, the remaining oil volume is weighed and compared to the original weight of the sample. The difference is reported as the percentage of weight lost.
In the SAE 40 testing (lower is better):
Royal Purple's evaporation was: 11.16%
Amsoil's was only 6.44%. In this case, RP's was TWICE as bad as Amsoil.
In the SAE 50 testing (lower is better):
Royal Purple's evaporation was: 9.23% (worst of all of the oils in the test)
Screaming Eagle was: 5.40%
Amsoil's was only 3.89%. In this case, Royal Purple's evaporation was almost 3x that of Amsoil.
Rust protection is measured using the ASTM D-1748 humidity cabinet test. The procedure calls for metal coupons to be dipped in the test oil, then placed in a humidity cabinet for 24 hours at 48.9° C. After 24 hours, the coupons are removed and inspected for rust. Oils allowing no rust or no more than three rust spots less than or equal to 1 mm in diameter are determined to have passed. Oils allowing more than three rust spots or one rust spot greater than 1 mm in diameter are determined to have failed. The degree of failure has been divided into three additional categories: 1-10 spots, 11-20 spots and 21 or more spots.
Amsoil: 0 rust spots
Royal Purple, Pennzoil, Golden Spectro, Valvoline, Motul, Royal Purple, Castrol, Bel-Ray ALL FAILED the test.
Now you can see why some of the people here who use Amsoil are raving about it. At least we have some numbers to go behind some of the raves.
Hope you found some of this helpful in your decision making. I recommend staying away from the Screaming Eagle. Remember, Harley doesn't make the oil. They go out to one of the lowest bidders and then they put a very high markup on the oil.
Amsoil is mail order. That's why you don't see it in the stores. They have warehouses all over the country making shipping super fast. Become a preferred customer and you can get wholesale pricing on the oil.
Hope you find this post helpful.
I noticed that Amsoil only compared their data to Mobile 1 oil in one category but to Royal Purple in most all categories. Is it because that was the only area where Amsoil excelled? Just food for thought. I use Mobile 1 in oil and transmission. Since I read the post/link from Lee about what Baker recommends, I use dextron/mercon ATF (NAPA) in my primary. :whoop::cheers::whoop:
djwilpers
Mobil 20w50 for air cooled motorcycle engines. I think it quiets the valve train down a bit more than other oils I've tried. I change it every 3000 miles and the filter. I have a HD Street Glide 110 and I use it in there also.
Chutney77
Newb Oil Change Question
I have always had my service done by a shop but want to start doing it myself.
I wanted to know how many quarts of oil to use. I am also not sure what the previous shop used. If they used a synthetic then i would have to use a synthetic as well, Correct? Or would I be able to use a straight v-twin motor oil?
Any other info is much appreciated.
2005 Big Dog Chopper
Thanks,
highrisk
AMSOIL in all three holes...... Home The way the oils are today, You can use conventional if you choose, weather you have ran synthetic of not. The two types of oils are compatible now days
Thanks,
First off, good choice. Not that I want to rob shops of work but because I think its good for a BD owner to get close to his dog and know her, sorry lady riders "Him", better.
Get yourself a scavenger unit:
..::Rogue Chopper::Welcome::..
you don't have to but I find, as do others here, that it makes a complete oil change eaiser but it is just a personal choice, takes about six quarts. Drain from the tank, I also drain the case but some guys think you shouldn't something about cross threading the drain plug and how hard it is to fix again personal choice.
You can also get yourself a K&P cleanable filter
Too Badd Customs: Products
again a personal choice
Oil itself is a personal choice as you will note from the number of different answers here. I personally use the new Amsoil 60w racing oil. I find it does the best job for me here in So Cal with the heat.
I run Rottela in the engine and BelRay in the tranny and open Primary
Rottela, thats a new one to me. I'm gonna go look that up right now.
Thanks RW
Looked Up
What drew you to Rottela RW?
I also see its made by Shell which is one of the companies that buys foreign oil. I try to buy from companies that buy US only, just a personal thing.
Mad Dog
ValueTeck Enterprises
Amsoil or nothing....I'm a dealer can ya tell. Seriously though, if you research it Amsoil is one of the best if not the best. And it's made in the U.S. There's an Amsoil banner on the first page of my website. Click the banner below and it will take you there.
