OMAR"S WELDING
i took my seat off on my 04 mastiff a seen the terminals have rubbed throuth the carpet or pad on the seat pan the pan is fiberglass so it not shorting out i checked under the battery and the pad is gone is this a problem
It may, some fiber-glasses are somewhat conductive.i took my seat off on my 04 mastiff a seen the terminals have rubbed throuth the carpet or pad on the seat pan the pan is fiberglass so it not shorting out i checked under the battery and the pad is gone is this a problem
Yes!if the pad is gone from under the battery would that make the battery sit lower?just sayn
As far as batteries go in relationship with BDMs, "Bigger is BETTER"! :2thumbs:iv had the bike for 4 years and the battery is the one thing i havent hade to replace had all the same problems as most on here
I had the same problem, if I sat on the dog it would not start and the Neg Cable would get real hot. If I took the seat off it would fire up. What I did was peel the carpet pad off and glued a 1/8 rubber pad to the seat bottom and then I sprayed some 3-M glue and put the carpet pad back on. I also changed the terminal from top mount to side mount. So far so good.i took my seat off on my 04 mastiff a seen the terminals have rubbed throuth the carpet or pad on the seat pan the pan is fiberglass so it not shorting out i checked under the battery and the pad is gone is this a problem
That's a much better idea! Good Idea Carlos! :2thumbs:I had the same problem, if I sat on the dog it would not start and the Neg Cable would get real hot. If I took the seat off it would fire up. What I did was peel the carpet pad off and glued a 1/8 rubber pad to the seat bottom and then I sprayed some 3-M glue and put the carpet pad back on. I also changed the terminal from top mount to side mount. So far so good.
Carlos![]()
