KaptinAmerika
Thanks for the part number oldmutt. I felt bad telling these guys to buy the HD battery but couldn't provide the damn number.
NJ,Yo Kona Dawg, glad it's not just me. Should make it easier to get it figured out. I didn't want to spring for a battery just to see if it would make a difference. The one I have, an Interstate that is 4 months old has been load tested on 2 different testers & the results were that it was fine, no problem. Mine is the same as yours "exactly". The first start is a "no start", honk, flash. Use a jump box & it's good to go for the day. I shut it off & started it 6 times in a row to check this out. If the battery showed any signs of not making the grade I would definitely replace, but it's okay. I leave the battery tender on it when it's in the garage so that's another thing that "it's not that". Also do not have an alarm or anything extra added on so that's another "that's not it". Check the battery voltage before attempting to start & it's anywhere from 13.36 to 13.42 so it's definitely not there either. Don't worry brother, we'll get this one figured out with people like gasman & others around. If you come up with anything that works you can e-mail me direct carlmyman@aol.com.
Remove the "rear"/ back of the starter "motor" and turn the drive end up and knock the bottom (open end) on a block of wood or something that won't damage the chrome or the stater. Then blow it out with compressed air. Might as well check the condition of your brushes while you're right there, check for free movement of the brushes and replace if necessary. :2thumbs:Hey "DeadOne", thanks for the info. I already cleaned soot from the solenoid. What did you do with the starter exactly. I don't have a diagram in front of me. Is there an end cap that unbolts or???? This may be the piece of the puzzle I'm looking for. If you can get back to me I'll give it a try either today or tomorrow. Thanks Bro I really appreciate the insight.
Use your feet, I do! :loony::crazy:makes sense,i just replaced rt side control pc,all is good,wish i had 4 hands sometimes:lol:
Hey Mobsta & TheDeadOne, sorry it took so long to get back (retired but still have a job). I think between the two of you the nail was hit on the head. Took the starter out today & here's what it looked like before & after. I'm taking it to a starter shop tomorrow or Friday to get it done right. Not sure I want to start popping the brushes out & going any deeper at this time. There was plenty of soot, carbon, schmutz all over. I can definitely see this causing my starting woes. No/bad contact with the brushes & the armature would cause amps/draw problems I'm sure. Should have it going back together by the weekend & I'll keep you all up on it. I really appreciate the help of everyone here. Check out the pictures & I'll get back to you.
These are the before (notice the red wire) and the after pictures (amazing what a little shot of electronics cleaner will do).
Sounds like a man speaking from experience! :2thumbs:Hey DeadOne, starter shops around me are getting scarce. Didn't want to leave it until Monday & hope they got to it so I did it myself. I got to say it wasn't any trouble. Held the springs out of the way to pop out each brush and cleaned them up with a small brass wire brush. Cleaned inside the brush housing with some electrical contact cleaner. Then took a piece of sandpaper with a paint stick as a backer to flat sand the front/contact side of the brush. Cleaned it all & used some brush oil a friend gave me. Uses it in his RC cars to help lubricate the brushes where they contact the armature. Prevents the brushes from scratching the armature. Also kept all the brushes popped out & cleaned the armature so it looks almost new (alright, it looks a lot better then it did!) . Wanted to put the starter back together but didn't have a dab of grease to hold the ball bearing which I guess to be a check valve of sorts in. Should finish it up in the next couple of days. I'll get some more pictures & keep everyone updated. Thanks again for the help bro.
NJ K-9
