NJ K-9
Hey Guys, help me figure out what' ailing my '06 K-9. To start, the battery is 4 months old, has been load tested twice in the last 2 weeks (different testers used each time) & came up fine, no problem here. Before starting the bike I check voltage and come up with 13.36 volts, I'm still figuring no problem here. Go to start the bike, cold, after sitting overnight or whatever, I get the starter cranking for about 1 second before the horn & flashers come on. I also checked to feel if the CR's are working & you can feel them pop when hitting the start button. If I use a "jump box" it will start fine. If the bike has been warmed up or run & still warm, it will start fine over & over. The initial start seems to be giving me the problem. Took the solenoid apart & cleaned up some soot, then used some emery cloth to finish it off. Also cleaned the contacts & sprayed the housing out before hitting it with emery also. Same no start. Today I took the plugs off the EHC & used electric contact cleaner to clean all, then filled with die electric grease. Also lightly sanded the battery terminals & cables to promote good contact. Same no start. Here's my thoughts, (hope I'm not sounding too long winded, just want to present as much info as possible), 1.Battery & charging are fine 2.Starter is fine Is there a missed step, or electrical circuit I'm not aware of? I'm not crazy about a slam button, but if it's necessary. Thanks for any & all help, insight, or guesses that get me heading in the right direction.
