Wire-Plus Install Experience
NascarNutCase
I just wanted to share with you my experience with installing the Wire-Plus WP-374 package into my 2004 Mastiff. First off, I'd like to extend to Jake my gratitude for tireless support whenever I had questions. You're super Jake mere thanks can never say enough. Surprisingly I didn’t have all that many questions either. I think the instructions were thorough and easy to understand.
Ok, at first I felt a lot of apprehension taking on this project. My biggest fear was I might screw it up some how. I am here to testify that the job does not require a rocket scientist to accomplish your goal. My first recommendation is to print off a copy of the CD instructions and sit down somewhere where you won't get interrupted or bothered by family or friends. No offense intended, but you know where I’m coming from here. Read the instructions all the way through, then read it again, then read it again. Trust me on this, it really was what helped me stay on the path to successfully completing this job. Next, when the instructions tell you to dig away as much of the silicone as possible, do it. You want all the wire length you can get. Another thing, before you cut any wires off the old EHC multi pin connector take the time to physically count the wire location you want, then count it again to make double sure especially when dealing with same color wires (reds mostly). Your grounds (black) wires are a no brainer, they all go together and it’s nearly the last step on the multi pin connector. So, if you accidentally cut a black wire don’t panic. If you haven’t ever tinned wires, it’s not that hard and it makes joining two wires together a lot easier. Get yourself some scrap wire lying around the house and practice a couple times on it for no lose situation when you go back to your bike. Tinning a wire is when you heat up the end enough to melt some solder on it enough that it coats it. Another thing to keep in mind, the kit I got had a couple spare Deutsche Billet Pins, so if you mess up crimping one, don’t panic. Once I got over the initial apprehension this project went very smoothly. If I can do this, trust me, you can do it too. Any of you people out there that have a Wire-Plus pack sitting on the shelf of your garage because you’re working up the nerve to tackle the job, stop waiting, you can do this too. Remember, read the directions at least a couple times and just apply some minimal wiring skills and you’ll have it. My bike fired up just as soon as the fuel hit the carbs. The next thing I noticed was all the little electrical problems I was experiencing were gone (tap on the headlight sort of stuff to get it to come on and I have high beam now too). Remember to pick up a couple 20A inline fuses and some shrink wrap to cover over your solder joints. If you don’t have a shrink wrap heat gun, you might be able to get the job done using the wife or girlfriend’s hair dryer. Otherwise, a bic lighter will do the same, just exercise a little caution that you don’t burn the shrink wrap. I would post a pic with this but by the time the photo is small enough to meet the requirements it's way too small to worth crap. So if you want to see it I'd be happy to provide it, just send me a PM. Mine looks presentable but in all honesty it's not going to win any beauty contests like some of the posted pics that Jake has. Anyhow, good luck everyone get that box off the shelf and get to it.
bdmridgeback
Low Down Chop Shop
Thanks guys!!!!
The Feedback is great, but I don't think it helps me as much as it tells people just how easy this Wire-Plus install is.
I just wanted to say thanks to all that have thanked me and to let everyone on the forum here know, that when you go to tackle that Wire-Plus job, I am here. Email, Phone, or in some local cases, I went right to those that needed me, and did the job!!:2thumbs:
Thanks again, and as they said, Dive in head first!!! It will be the best thing you ever did!!! :cheers::cheers:
bdmridgeback
Low Down Chop Shop
Just don't fire up a bic lighter to do any shrink wrapping near the gas tank. :eek:
...Or... When your done with your wire job, Install all your shrink wrap, crack the tank open, and flic that Bic!!!!
...Hang on tight and you have instant shrink job in one easy step!!!!:2thumbs:
C
chaingunner
Guest
Ditto! I just finished mine and couldn't be happier! Easy job! I had NO electrical knowledge, (now I do) and I did it! :2thumbs: Couldn't be happier! Next? Thunder Heart, and the bruiser clutch!
TCALZ06
Hi, Did you have problems with your 07 before you did the change? I haven't had any but I've been watching about these kits in case.
I've got a battery issue that I hope isn't wiring related. I've gotten two Harley batteries in the last year and a half that are weak. I keep a tender on it all the time and sometimes it doesn't have enough power to turn over. The reason I think it's the battery is because when it happens the speedo doesn't work either and that means the battery is low on charge. I just ordered a Braille battery so I'm waiting to see
C
chaingunner
Guest
Hey TC
I didn't have any problems, I had to keep it on a tender like most of us do, but Jake ran a special last Oct, and I was watching what EHC's were going for and I couldn't pass up the price, in the end it cost me a whopping 2 bones to do this change, and to me that was worth the ease of NEVER having the possibility of a failed EHC. It may never have happened, but its all about piece of mind with me. I also went with a Braille and am super happy with that as well. I have noticed that my bike cranks over alot easier..... why? no idea< except I figure the battery isn't strained like it used to be, I DONT have to keep it on a tender now, (I later found the EHC never stops draining power....even when the key is off) I have went a week and a half and the bike still started easy. Before the battery was so low I usually had to put it on the tender b4 I even thought about starting. Hope you get it figured out!
Escobar
Did one last night myself, got half way done with it at least, I got as far as connectiong all the wires to all three plugs and called it a night after that because I installing the ignition switch was next (and that calls for a little cutting). I too was surprided how detailed Jakes instructions were and how easy everything just flowed. I do have one suggestion though, at the begining when he explains which connectors are which (i.e. 1, 2, & 3) mark them with a sharpy on both sides and it made it a lot simpler identifying which connector to grab just from a visual. I'll start on the switch tonight and should be riding shortly after. Couln't be a better time either, forcast in my area calls for 7 days of sunshine at 73 degrees.
C
chaingunner
Guest
I used the sharpy also! :2thumbs:
BadBrad
2005 Pitbull
Hi Jake,
My WP-374 came in last week and it didn't have a Sharpie. They must have left it out. Can you check my invoice and see if I was charged for it?
:roll::roll::roll::roll::roll::roll::roll::roll:
Pops
Thanks to Jake and Moespeeds I also am EHC free :2thumbs:
Have an 06 with 4000 trouble free miles so if anyone wants a spare EHC (never a problem) cheap just PM me.....
NJ K-9
Sorry to say Pops no longer has the EHC. It's been transplanted in my 06 K-9. Doctor reports surgery was successful. Thanks Pops
GDOG_PITBULL
I will also say that the change is easily accomplished by most anyone. I will also say that without Jake's help, I would have had a much tougher time! His help is invaluable!!!!:2thumbs:
G
