Escobar
Hi guys, I could use a little help trying to trouble shoot my bike. Took it out a couple days ago and the other day I wanted to go for a ride, It just wouldn't fire. I originally thought it was cam sensor that wasn't allowing the Thunderheart to recieve a signal because the red light on the module wasn't blinking. I changed the sendor out and still it wouldn't fire. started to look deeper and checked the coil and then the EHC.
At the primary side of the coil i don't have voltage on either side and when checking the resistance it appears to be fine as it reads 3 ohms across both sided with key off, and 14.9 K Ohms at the secondary or end of the plug wires.
Started looking into the EHC and when checking the voltage i get 12.65V from the Battery but only about 9V to the Thunder heart, 0 V to the Coil and my headlight won't even turn on (10V). Does anyone know if the 12V should be distributed throughout the entire electrical system or the voltage drop im seeing from the EHC is normal.
Is there anything else I could do that would help me determin what is wrong this this Mutt. I leaning heard towards the EHC but don't understand why it would just crap out on my like that.
Thanks!
Thanks!
