PureDestruction
coilSo we can keep track of where we are...
Coil values as measured with coil wires disconnected-
1. primary (between red and yellow, should be ~3 ohms, meter on "200" ohms) = 3.3
2. secondary (between spark plug wire holes, should be 13K to 14K ohms, meter on "20K" ohms) = 11.63
Cam sensor values as measured on the pigtail going to the sensor (you can just set your meter on the "2M" ohms scale for all of these) -
1. From each wire on the pigtail to the backing plate (black lead on plate, should be "open") = meter doesn't change
2. With red lead on green wire and black lead on black wire (should be "open") = meter doesn't change
3. With black lead on green wire and red lead on black wire (should be 300K to 750K ohms) = meter doesn't change
Just "quote" this post and put in the numbers that you get...
Dennis
PS Just remember, with your meter turned "on" an "open" looks just like what you get on any ohms scale (the range from about 10 to 1 o'clock) with the leads not touching anything. Make sense?
