Why the hell would someone design this???
GDOG_PITBULL
WTF would someone design a starter system that you have to remove the primary cover and unbolt some shit to get the starter out of the bike? Unfucking believable :job:
Pissed!
G
Pissed!
G
That's HD's system!!! :D
One of the reasons I like the Baker setup. :2thumbs:
nobozos
had mine in and out three times before it was finaly right, took the starter to a reman shop here in phx az when it would not start after I trailered it home and they replaced the wire that engages the selinoid I beleive, and it burnt again, trailered it home again and they replaced the # 14 awg with a # 10, trailered it home again and we took it apart, every screw nut bolt coil winding etc while I was there in his shop and found that at the factory when it was built there was a thick steel housing that fits around a coil that was never crimped together giving only an intermitant path to ground, i hope this helps someone to know that while it is out and apart they need to look deep into everything cause like you said what the $#&$#
p.s. not a mechanic hope it made since.
GDOG_PITBULL
Fuck.....................
kona dawg
Could be like me. I took the 2 bolts out(after the exhaust) and it didn't drop so I figured I had the bolt in the primary. Took primary off and no bolt. Went back and jerked on starter again and it came right out. What a dumb ass I was. My lead from my solenoid to starter was loose and corroded. Hope that was my problem. Started today who knows about tomorrow
RADAMS445
RADICAL
Most have been there and done that! The trick is not to admit it!:roll::roll:
