2003 Thunderheart module red LED
aris
somebody knows in 2003 mastiff on Thunderheart ignition module what monitor red LED ? and it must be on or off.
Can you re-write that again so we can understand what it is you are asking for?
There is no on and off switch for the lights on the ignition module so don't understand your question. Could you be referring to the Run/Off switch on the handlebar?
aris
on Thunderheart ignition module is one red led light and is stays on when my bike is running, so should it lit or no ,and what it means. thanks.
sh8kr
The red is an indicator from the cam ignition trigger, while the motor is running it will be solid red. The light will flash while cranking the motor (during starting ). This is a good question, knowing about the Red light will help you troubleshoot why the bike will not start later.
Steve C
When I turn the key the red led light comes on, but then turns off, and the bike just turns over and over, but will not start... NO LED WHEN CRANKING
That means the unit is getting power. RED light is supposed to go on just for a second on the 04 then off but it should blink when cranking.
Check your cam sensor. If you need one, I will include a 3 pin JST plug for you in your order as that is what was used on 04.
Pull off the cover on the nose cone and there is some information on the forum for the testing procedure, although you may not need to test it if it looks melted which has happened over time with the heat from the motors.
Must be cam sensor week....
Antcoy420
Might be a dumb question but now that I fixed all the wires, finally getting lights to my ecm just to find out I still cant ride tonight or tomorrow... unless there is a way I can bypass the sensor? Just temporarily! And how much for the part
Can't bypass the cam sensor. That's what sends the signal for timing on the spark. Looks like it got a littled melted by the pics.
The link in my original post to get you a new one.
Sent from my moto z4 using Tapatalk
Nick p
Steve C
My red light is on even with the key off and my bike wont start.12v going to the thunderheart ignition 12 coming out 12 going to coil no spark
Badazz
How do I find the testing procedure I searched cam sensor testing and it said nothing found
