Arlin Ness air intake with elbo
bigbird99
Do you have to rejet your carb when changeing air intake.I had the half skull intake along with Vance & Hines big radus pipes.The bike ran good. I changed the air intake and now a about 1/2 throtel it bogs down or trys to choke down. I am thinking i need bigger jets. I have been told to run 32/76 jets. I have a 107 with G carb. Help Thanks
outdoorsman26
what filter you switching too?? It may be that its not getting the air it really needs... do you still have the stock one if so try it b4 you spend time ripping your carb apart!! your jets should be fine if you are running around sea level
Bogging down and choking down could mean to some that you are running to rich.
On my 117 I run a 29/72. Can't remember what I ran in my 03 with the 107.
outdoorsman26
I run those in my 117in might be a lil heavy for your motor im not positive but there is someone on hee tht will tell ya!!
BikersDream
We build what you Dream!
You could use a good Dyno tune! Dont guess. Get it right:2thumbs:
bigbird99
Rejet your carb.
I installed new jets that fixed the prob. I went too 32/76 on the new jets. The old ones were 29.5/70 . This has helped a lot thanks.
