battery question
bigdog107
Beware Of Dog
I got a Braille racing bat so i can put my new lowrider seat pan on. It says its a 10 amp 210 cca 527 pca bat. it seems to not have the power of my old bat. Is this enough bat for my bike?
mobsta
i think big boar makes a small battery,may have to drop down the battery box,just a thought:cheers:
bigdog107
Beware Of Dog
ya i have been thinking of droping it a inch or so but dont wanna unless i have to. I have to get my seat pan out to Seatmaker in a week or so cause Daytona is getting close so i got to figure it out this week. I will check on Big Boar though thanks
bigdog107
Beware Of Dog
Little, I need it to be under 5 inches tall to fit it in there with out hitting the bottom of my seat pan. That looks like a great bat though i got the Braille BR-B106
I would say if you are going to use that little battery rated at 210 CCA then you are sacrificing starting reliability for cosmetic reasons.
You should show us a picture of the seat pan so we know what you are describing. Does the pan sit inside the frame rails? Seems you would have plenty of room as many members here have installed these type pans without problems like your describing.
bigdog107
Beware Of Dog
My seat pan is a Instapan seat pan and it is flat across the top of my frame and there is about 5.5 inches of height thats why i got a braille because it is only 4.25 high. Maybe i need to lay a bigger braille bat on its back then i think i can go to about 5.5 high bat if its on its back. I will get off my lazy ass and upload a pic in 5 mins.
chihuasbigdog
LATINAMERICAN AFFAIRS
Here is the Battery I got and it's a kick ass Battery. Fits perfect no adjustment to anything,
just bolt it on and you're good to go.
Braille Battery USA - B2015
Carlos :whoop:
me too!!! unbelievable batterys!!!
dog was 45 days parked in cold weather (due to fuckin EHC :angry:) no tender also, and when I changed it, Dog started at the first time!!!
VROOOM VROOOOOM.
have been using these for the last 2 dogs, no prob at all!!!
bigdog107
Beware Of Dog
I put the posts on the top just for charging they will go on the side when i am done with everything.
bigdog107
Beware Of Dog
Like i said i got them on top just for charging it up not for everyday use. The bat needs to be under the frame rails i am thinking of going with a lithium bat if i cant get a bat from braille to fit in there.
mobsta
i talked to my friend today that had issues with clearance and it was the big boar battery that he used,he said its supposed to be the smallest with the most cca.he didnt remember the exact but its over 300cca,good luck:cheers:
