beagle man
Hey guys does any one know wear i can get my starter beef up the stock starter just can't take the motor just fries it.Beagle Man
in the same boat but my starter spins no problem. took it to a local alternator shop and he beefed it up for 100 bucks.underlying issue is the jacked up compression and 127 hp., might get a little easier after breaking the motor in again.
Unless they downgraded for the 09's your starter is already a 2.0kW with 2.4 max kW. Here is the tech sheet you get with each starter from BDM.Hey Dude thanks for the help.The compression reliefs are working,the battery was tested ok.With the work done on the motor i have 230 lbs torque that that starter has to turn to start that motor.I will try to get mine beefed up or i will go with a Tech cycle 2.0kwt the stock are 1.5.Nick
