Winter Mod Front end
Shredder
So I usually do something fairly major to my bike every winter during the cold weather down time. I have always wanted to change the forks on my Ridgeback, as Marv has said, the front end on the chopper style bikes looks too thin for the overall fatness of these machines and I couldn't agree more. My problem has always been the cost of replacement front ends, until Ultima decided to blow out most of their $2,000 front ends for about $500! So I took the opportunity to:
Buy an Ultima 58MM (5 degree rake in the trees) inverted front end for $529, then sold my stock front end on Ebay for $521. I think the painted headlight really stands out now without being flanked by stock turn signals. Speaking of turn signals....
West Virginia requires turn signals for inspection so I had to find a solution to keep those. Turn signal mirrors seemed like the obvious choice, but most of them are fairly rounded like the Kuryakyn so I needed to find something with some attitude. Finally found the Badlands turn signal mirrors you now see on the bike. These turn signal mirrors are perfect, except for one minor issue, $400 retail! Ouch, but they are perfect in my opinion and I made out on the front end price so what the hell.
I had just installed the S&S dual runner intake after they dropped the retail from $800 to $500. This is a very good breather in my opinion, but I didn't like the filter clamps or end caps being made of aluminum as I felt it didn't look right against the powder-coated engine. So I shipped the filters to Julio to have him paint the end caps to match the paint he did on the rest of my bike. Much better in my opinion, it's all in the details right?
As always I appreciate everyones input and opinions.
Shredder
Shredder
I understand the issues with the TP rocker boxes. My top end was apart last winter for the engine tear down for powder coat and there was no issue at that time. I plan on converting to S&S next winter and sending the heads to John Sach for some performance mods.
Shredder
Byrddogg
Awesome job :2thumbs:
Where are you going to end up putting the blinkers?
So this front end just bolted straight up no cutting or any major fab work??
Like I said "AWESOME" but your bike is one of the best looking here so you already had it covered :cheers:
Shredder
Byrddogg,
Sorry for the confusion, the Badland mirrors do have the turn signals built in, if you look at the first pic you can see the turn signal dots on my right side mirror pretty well, these are in fact quite bright. No modifications necessary to install the front end though. I did need to buy another bracket for my 360 brake. Thank you for your comments.
Shredder
choppersforlife
CHOPPERSFORLIFE
Sweet
Nice job.
Question : What about the Brace between the forks ? Does that front end require one ? Love the look.
Ride Safe
MARV
Nice job.
Ride Safe
im running that 58mm front end without a fender and it does twist when i grab a bunch of front brake. the fender and mounts acts like a brace but it is low on the forks.
ultima sells a brace for the 58mm. Moespeeds had one but i believe he said it kept sliding down the taper of the tubes.
Tim
Founder
Lifetime Supporting Member
That looks sick and I love the paint. :2thumbs:
