Installing new handlebar bushings
IrishGuy
I'm installing polyurethane bushings on my handlebars. Can someone help me verify the proper torque value for the two handlebar bolts?
In my '05 service manual on page 10-12 it lists the bolts as: 1/2-13 x 2-1/2", HHCS, SS, POL
On page 10-2 it has a matrix of torque values for different bolts. For 1/2-13 it has these values:
47 = SAE 0,1,2
69 = SAE 3
78 = SAE 5
106 = SAE 6
110 = SAE 7
119 = SAE 8
Does anyone know which it is? Should I assume 47? And the matrix has no units :bang:. I don't know if things are in-lbs or ft-lbs. :confused:
lee
47 in lbs is next to nothing so it won't be that. Just put some loctite on there and do nice and snug and you'll be fine.
boydog
torque
47 = SAE 0,1,2
69 = SAE 3
78 = SAE 5
106 = SAE 6
110 = SAE 7
119 = SAE 8
65 ft lbs
47 = SAE 0,1,2
69 = SAE 3
78 = SAE 5
106 = SAE 6
110 = SAE 7
119 = SAE 8
1/2-13 would not be listed in inch#. SS would be stainless steel
IrishGuy
ok, finally got them installed. wow, what a difference too! The main reason I replaced them was the throttle cables were touching the tank in a turn.
With the new polyurethane bushings the cables are *completely* clear of the tank. My grips are about 2 inches higher now too. :eek:
I've had the rubber ones replaced in the past and they only lasted 2 years. These ones should hold out much much longer.
Now I just have to wait for all the snow to clear :bang:
