Service Bulletins 2006 K-9 - Search Results
Navigate: ODI Home » Service Bulletins » Results List
Search Results
Report Date : January 7, 2010 at 12:33 PM
Search Type : VEHICLE
Year : 2006
Make : BIGDOG
Model :
"K-9" Note: Listed differently and some SB# are different.
Results : 22 | All records displayed
Make : BIGDOG Model : K-9 Year : 2006
Manufacturer : BIG DOG MOTORCYCLES, LLC
Service Bulletin Number : 07V580 Date of Bulletin : OCT 30, 2008
NHTSA Item Number : 10026469
Component :
SUSPENSION:FRONT:MACPHERSON STRUT
Summary :
BIG DOG MOTORCYCLE: STRUT BOLTS REPLACEMENT. REMOVE STRUT BOLTS AND INSTALL STRUT BOLT KIT P/N 243 000010-00. *PE
Check to Request Research. Submit below.
Service Bulletin Number : SIL-0008 Date of Bulletin : MAY 11, 2008
NHTSA Item Number : 10026442
Component :
EQUIPMENT:OTHER:OWNERS/SERVICE/OTHER MANUAL
Summary :
BIG DOG MOTORCYCLE: ELECTRICAL SIDE COVER CONTACT WITH BELT GUARD. A WIRE BUNDLE MAY PROTRUDE INTO THE RIGHT ELECTRICAL SIDE COVER. *PE
Service Bulletin Number : SB-1106 Date of Bulletin : APR 18, 2008
NHTSA Item Number : 10026833
Component :
Summary :
BIGDOG MOTORCYCLE: NEW PRIMARY INSPECTION COVER GASKET. INSTALL NEW INSPECTION COVER GASKET ON ALL 2005-2008 BIG DOG MOTORCYCLES. *PE
Service Bulletin Number : SB-1102 Date of Bulletin : APR 11, 2008
NHTSA Item Number : 10027045
Component :
EQUIPMENT:ELECTRICAL
Summary :
BIGDOG MOTORCYCLE: HIDDEN SHOCK ELECTRICAL COVER HARDWARE REPLACEMENT. ELECTRICAL SIDE COVERS MAY CRACK OR BREAK. 243-000011-00 FOR ALL MODELS EXCEPT 2006 K9. 243-000013-00 FOR 2006 K9 MODEL. *PE
Component :
EQUIPMENT ADAPTIVE
Summary :
Component :
EQUIPMENT
Summary :
Service Bulletin Number : 07-V-580 Date of Bulletin : JAN 14, 2008
NHTSA Item Number : 10026614
Component :
STRUCTURE:BODY
Summary :
BIGDOG MOTORCYCLE: REAR FENDER STRUT BOLT REMEDY. REAR FENDER STRUT BOLTS MAY FAIL ALLOWING THE FENDER TO DETACH FROM THE MOTORCYCLE. *PE
Component :
STRUCTURE:BODY:BUMPERS
Summary :
Service Bulletin Number : SB-1099 Date of Bulletin : JAN 11, 2008
NHTSA Item Number : 10026832
Component :
FUEL SYSTEM, OTHER:STORAGE:TANK ASSEMBLY
Summary :
BIGDOG MOTORCYCLE: FUEL TANK VENT MAY BECOME FLOODED WITH FUEL, CAUSING THE MOTORCYCLE TO RUN POORLY DUE TO A FUEL MIXTURE THAT IS TOO RICH. *PE
Service Bulletin Number : 1092 Date of Bulletin : MAY 18, 2007
NHTSA Item Number : 10023092
Component :
VEHICLE SPEED CONTROL
Summary :
BIGDOG MOTORCYCLES - REVISED SPEEDOMETER AND MOUNT. *NJ
Service Bulletin Number : 1069 Date of Bulletin : NOV 03, 2006
NHTSA Item Number : 10020064
Component :
ELECTRICAL SYSTEM
Summary :
INTERMITTENT PRINTED CIRCUIT BOARD OPERATION. *TT
Service Bulletin Number : 1090 Date of Bulletin : AUG 25, 2006
NHTSA Item Number : 10020374
Component :
POWER TRAIN
Summary :
ROUGH SHIFTING, OR NOISY TRANSMISSION CAUSED BY LOOSE TRANSMISSION COUNTERSHAFT SCREW. *TT
Service Bulletin Number : 1088 Date of Bulletin : JUN 30, 2006
NHTSA Item Number : 10020152
Component :
COMMUNICATIONS:HORN ASSEMBLY
Summary :
HORN HARNESS WIRES MAY BREAK. *TT
Service Bulletin Number : 1086 Date of Bulletin : JUN 30, 2006
NHTSA Item Number : 10020153
Component :
POWER TRAIN
Summary :
NOISY PRIMARY CHAIN, OR EXCESSIVE DRIVE TRAIN VIBRATION. *TT
Service Bulletin Number : 1078 Date of Bulletin : JUN 23, 2006
NHTSA Item Number : 10020045
Component :
ELECTRICAL SYSTEM
Summary :
EHC CONTACT IMPROVEMENT PROCEDURE (REVISED). CURRENT SEAL DOES NOT ALLOW CONNECTOR PINS TO SEAT PROPERLY AND MOISTURE MAY BE PRESENT IN CONNECTOR. *TT
Service Bulletin Number : 1077 Date of Bulletin : JUN 16, 2006
NHTSA Item Number : 10020065
Component :
EXTERIOR LIGHTING:HEADLIGHTS
Summary :
HEADLAMP CONNECTOR MAY MELT, MAKING BULB REPLACEMENT DIFFICULT. *TT
Service Bulletin Number : 1081 Date of Bulletin : MAY 04, 2006
NHTSA Item Number : 10019963
Component :
POWER TRAIN:MANUAL TRANSMISSION
Summary :
SHIFTING DIFFICULTY CAUSED BY LOOSE TRANSMISSION COUNTERSHAFT SCREW. *AK
Service Bulletin Number : 1075 Date of Bulletin : MAY 03, 2006
NHTSA Item Number : 10019909
Component :
ELECTRICAL SYSTEM
Summary :
DIELECTRIC GREASE ADDITION TO CONNECTORS. *TT
Service Bulletin Number : 1080 Date of Bulletin : APR 27, 2006
NHTSA Item Number : 10019984
Component :
STRUCTURE
Summary :
TACHOMETER BOARD REPLACEMENT - INACCURATE TACHOMETER READINGS OR FLUCTUATION IN READINGS DUE TO MOISTURE. *AK
Service Bulletin Number : 1072 Date of Bulletin : MAR 27, 2006
NHTSA Item Number : 10018991
Component :
ELECTRICAL SYSTEM
Summary :
INACCURATE SPEEDOMETER OPERATION - VIBRATIONS AT HIGH SPEED ARE CAUSING SIGNAL LOSS TO NEEDLE FROM SPEED SENSOR. *TT
Service Bulletin Number : 1070 Date of Bulletin : JAN 04, 2006
NHTSA Item Number : 10019118
Component :
POWER TRAIN:CLUTCH ASSEMBLY
Summary :
CLUTCH CABLE GUIDE REPLACEMENT. CABLE MAY CONTACT FUEL TANK AND RUB PAINT. *TT
Service Bulletin Number : 1071 Date of Bulletin : DEC 21, 2005
NHTSA Item Number : 10018992
Component :
FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY
Summary :
EXCESSIVE VIBRATION AT TAIL END OF FUEL TANKS. *TT
Service Bulletins - Search Results
Search Results
Report Date : January 7, 2010 at 12:48 PM
Year :
2006
Make : BIGDOG
Model :
"K9" Note: Listed differently and some SB# are different.
Results : 9 | All records displayed
Make : BIGDOG Model : K9 Year : 2006
Component :
Summary :
Service Bulletin Number : SIL-0001 Date of Bulletin : APR 18, 2008
NHTSA Item Number : 10026428
Component :
Summary :
BIGDOG MOTORCYCLES: THIS LETTER HIGHLIGHTS THE DIFFERENCE BETWEEN THE VARIOUS ELECTRONIC HARNESS CONTROLLERS (EHCS). FOR MODELS YEARS 2005-2009 MOTORCYCLES. *PE
Component :
EQUIPMENT
Summary :
Component :
EQUIPMENT ADAPTIVE
Summary :
Component :
Summary :
Service Bulletin Number : R07V-580 Date of Bulletin : JAN 14, 2008
NHTSA Item Number : 10026245
Component :
STRUCTURE
Summary :
BIGDOG MOTORCYCLE: REAR FENDER STRUT BOLTS ON CERTAIN MOTORCYCLES MAY FAIL ALLOWING THE FENDER TO DETACH FROM THE MOTORCYCLE. *PE
Component :
STRUCTURE:BODY
Summary :
Component :
Summary :
Component :
Summary :
:2thumbs:
