How do you lock the primary/clutch to remove primary nut?
Nomad2day
Longhair Redneck Geek
is that the clutch basket lock nut that the spanner is on?:confused:
No,
That is the primary nut the wrench is on....
The clutch basket is on the other end of the chain not pictured here..
I just used a rag without anything in it and a electric impact wrench to loosen the nuts...
Neil
kiwi
No,
Neil
thanks neil:2thumbs:
lee
what you need to think about with the clutch hub nut though is that you need to also lock the inner hub to the outer. To do this I bolted two old clutch plates together - one steel and one friction.
