Tranny oil quantity
Gabriel
Anyone know the physical quantity of a 2003 chopper LSD 6 speed Baker transmission?
Yes I searched, yes, I know how to check it.
I did not find it in the owners manual either.
Thanks
Gabriel
No problem,
Hey how do you like the B-King? As good as the busa?
I love the thing, I used to ride a Busa but they are uncomfortable for my old ass, so I sold it and was sorry ever since.
So I bought this a while ago and as you know it has the the second generation Busa engine.
It's hard to believe they sell these to just anyone, you should need a pilots license to operate it.
It is very comfortable and will probably drag my BD faster than it will go on it's own:lol:
But they are not in the same league.
There is a side of me that likes the forward thinking engineering that is on the tip of technology and devoid of any crudeness.
I have always had a Harley because that is what I grew up on starting at 14.
I still believe that the true sound of a motorcycle is a big V-twin and i have always loved the big choppers and think these BDM look excellent! Yes i keep it in the house, it's right in the living room.
[/IMG]
Gabriel
What are the differences in the 1st and 2nd gen engines in the busa?
Technical revisions
Engine changes consisted of an increase in stroke by 2 mm, enlarging displacement to 1,349 cubic centimetres (82.3 cu in). The compression ratio was boosted from 11:1 to 12.5:1 and the cylinder head was made more compact and was given lighter titanium valves, saving 14.1 grams (0.50 oz) and 11.7 grams (0.41 oz) on each intake and exhaust valve, respectively. The valves were driven by a chain with a new hydraulic tensioner. The pistons were made lighter by 1.4 grams (0.049 oz)[39] and used ion-coated rings and shot peened connecting rods. The crankcase breather system had reed valves added to control pressure waves in the intake airbox, a way of avoiding power loss.
Fuel injectors from the GSX-R1000 were used, with smaller 44-millimeter (2 in) throttle bodies, called the Suzuki Dual Throttle Valve (SDTV) system. It has selectable three options of power delivery for a range of touring to wide open high performance.[38] The exhaust system was overhauled, using a 4-2-1-2 system, meaning four exhaust outlets merging into two pipes, and then joining into a single pipe before splitting into two enlarged, quieter mufflers, which added a few pounds of weight compared to the first generation Hayabusa. The exhaust also included a catalytic converter and an oxygen sensor in order to meet Euro 3 emissions requirements.
The suspension was upgraded with a 43 mm Kayaba inverted fork with sliders having a diamond-like carbon (DLC) coating. The rear shock is also a Kayaba, and the overall suspension is firmer than the previous model. The swingarm is similar in design to the old one, but was strengthened. Front and rear remain fully adjustable. The transmission was given a heavier-duty, slipper clutch. The final drive ratio was slightly lower, and gears 5-6 were spaced farther apart, and gear ratios 1-2 moved closer together.
Ergonomic and cosmetic changes for the 2008 model include a higher windscreen, and interlocking gauge faces with a digital speedometer, as well as a new gear indicator and adjustable shift light. The fairing fasteners were hidden to uncomplicate custom paint work. The twin-spar aluminum frame was carried over from the previous version, and wheelbase, rake/trail, and seat height were the same, while overall length grew by two inches, and the taller windscreen added about 1/2 inch.[26] Weight was saved by omitting the centerstand.[4]
Technical improvements in the chassis include Tokico radial brake calipers, allowing smaller discs and therefore lower unsprung weight, translating into superior handling. Increased front braking power[27] necessitated a sturdier lower triple clamp. The rear brake caliper was moved to the top of the disc, giving a cleaner visual appearance. New 17 inch wheels were designed, using Bridgestone BT-015 radials taken almost directly from the GSX-R1000.[4]
Other changes were a steering damper with a reservoir and dual cooling fans with a larger, curved radiator. Because of increased vibration from the longer stroke, the fuel tank was put on floating mounts. All told, the changes for 2008 resulted in a dry weight of 490 pounds (222 kg), 5 pounds (2 kg) heavier than the prior generation.
[edit] Other developments
Suzuki has dropped the GSX1300R designation in some countries and simply called the motorcycle the Hayabusa.
There are no changes for the 2010 model year except new colors.
Alongside the second generation Hayabusa, Suzuki developed the new B-King, a naked bike in the streetfighter mold, using the same engine but with a different intake and exhaust.
Horsepower ↓ Torque ↓ Weight ↓
194 bhp (145 kW) 115 foot-pounds (0.156 kW) 220 kg (490 lb)
Gabriel
I was just looking for info on the B-king. Not many even know about this bike.
thx:cheers:
They were not popular here in the US so 08 the only year it was here. It's popular in Europe where naked bikes do well.
Most thought it was just too ugly when it arrived, but several bike models have gravitated towards this looks since then plus it is one of the bikes in the new Transformers movie.
It has the best wind protection of any bike I have ever ridden, it must have something to do with the wide tank?
Most people that were thinking about a purchase and got a chance to ride it, bought it. It is smooth with a comfortable riding position and completely adjustable suspension. It rolls in the chicken strip with the best of them and I lowered it 2" in the rear also.
The power is more than impressive (mid 9's). The front tire has less miles than the rear because it will power up through second and then up some in third. I don't do much of that, maybe once every outing. I put a throttle master on it and at 50/60 you can ride it all day with no hands even around shallow curves, it tracks like a Busa. I gotta have something that corners and it fills the bill. I flat tracked Harley's in my youth and I like a bike that corners. I'm getting to old for that now and I guess when I fall off (again) I will quit:eek:... (maybe)
[/IMG]
