The day I picked up my bike I road it home about 200 miles and as I was getting home it died. As I got a little anxious I checked to see if I had gas and noticed a bunch of air pressure was released when I popped off the gas cap. I later found out this happens.
Well today I've been fumbling around with my new pipes, jets, carb, etc. and after I thought I had it tuned I rode for about 20 minutes filled up the tank wtih gas and was gonna go check out how it was running. It road for about 10 more minutes before it started sneezing, like it was about to run out of gas. I pulled over. Not sure what it was...at first I thought I hadn't adjusted my carb properly, then I had an issue with gas filter earlier in the day, that wasn't it. Then sure enough I took the cap off, a ton of pressure was released and the dog fired right up and started hauling ass again. It started sneezing again 10 minutes later and then I just went home.
What causes this? Why now after I changed my pipes? And whats the fix?
Thanks guys.
Thanks guys.
