Yes you can use a car battery, as long as the car is "NOT" running!If I connect my bike to a car battery with the car not running to start the bike will it do any damage to my bike?
Agreed, use much caution to the connections being correct! :2thumbs:I would not take the chance with a $400 EHC. Find another motorcycle battery or a lower amperage jump box. Maybe a smaller lawn mower battery or something like that.
:2thumbs: There is a "BIG" misconception about jumping BDMs! Jumping the BDMs from any battery can only "possibly" cause the (older models) fuse to blow, (newer models) main breaker to trip, due to excessive current being drawn while cranking with the dead battery trying to "recharge" itself at the same time from the jumping battery. A larger battery or while a vehicle is running, only adds to the potential possibility of a problem. But nothing else blows up or gets damaged if connected properly, and nothing else on the bike that isn't possibly already damaged previous to jumping.I was thinking that if the car is not running it would not damage my ehc
:iagree:Yes you can use a car battery, as long as the car is "NOT" running!
:nono: But it won't hurt the EHC as long as the car is not running and it's not connect improperly. EHC doesn't know whether the batt. comes from car, bike or lawn mower. And the added amperage rating won't matter either way, the EHC only pulls what it requires. :2thumbs:
Now that's putting things in "Simpleton Terms"!:iagree:
Making sure the voltages are the same is the most important thing followed by making sure you connect things in the proper order!
1. First connect a red clamp to the (+) positive post on the dead battery. Then connect the other end with the red clamp to the (+) positive post on the good battery.
2. Next connect a black clamp to the (-) negative post of the good battery.
3. Now connect the remaining black clamp to a solid piece of grounded metal if possible (it's best if it is clean and non-painted). Avoid connecting this clamp to the negative post of the dead battery if you can. (There's less chance of making a spark that way!)
Bon Apetit!
Dennis
the fuse or breaker is inline of the VR and battery.:2thumbs: There is a "BIG" misconception about jumping BDMs! Jumping the BDMs from any battery can only "possibly" cause the (older models) fuse to blow, (newer models) main breaker to trip, due to excessive current being drawn while cranking with the dead battery trying to "recharge" itself at the same time from the jumping battery. A larger battery or while a vehicle is running, only adds to the potential possibility of a problem. But nothing else blows up or gets damaged if connected properly, and nothing else on the bike that isn't possibly already damaged previous to jumping.
in between them :2thumbs:, yes!the fuse or breaker is inline of the VR and battery.
what protects from any 'spike' from jumped battery to electronics?
Exactly!!! Yes the EHC does have built in protection to allow small excessive load draws to trip the circuit breakers inside. However, the EHC is the weakest link and can and will burn itself out if receiving too many amps. Why do you think it would make a difference having the car on or off? I have replaced numerous EHC's and a lot of them burned out from using a car battery, even with the car not running. You are better off charging the battery overnight or going to a Harley dealer and buying a new battery. Your MAXI fuse or main circuit breaker will not protect your EHC. The EHC receives power directly from the battery. The only thing the Maxi fuse or circuit breaker is hooked into is your charging system, Voltage Regulator (hooked between Battery positive and voltage regulator) Nothing else should be hooked into this.the fuse or breaker is inline of the VR and battery.
You say "Yes the EHC does have built in protection to allow small excessive load draws to trip the circuit breakers inside."Exactly!!! Yes the EHC does have built in protection to allow small excessive load draws to trip the circuit breakers inside. However, the EHC is the weakest link and can and will burn itself out if receiving too many amps.
With the automobile "running" the charging system of the automobile is operating and directly connected to the battery.Why do you think it would make a difference having the car on or off?
A 12 volt battery, is a 12 volt battery no matter what the CCA rating is. Are you saying that the EHC can tell what CCA the battery is, connected to it?I have replaced numerous EHC's and a lot of them burned out from using a car battery, even with the car not running.
