I have 2008 k-9 with 3k miles. Vibration noise started about one thousand miles ago. Comes on at 2700 rpm. Does not affect handling or engine performance But is so loud that it nearly drowns out sound from Vance and hines 2 in one pipe.
Any ideas where to first look???? Thanks..
Metal vibrating? I guess you have already felt around for anything loose. Have you checked your motor mounts, tightened your exhaust pipes (including your bracket holding the pipes to the side of the bike)? Does it sound internal, e.g. gears, clutch, primary chain? Need a little more info. Does it come from the front, rear or motor?
