Drag Pipes
KnotSo
Admin
I looked up Raywoods exhaust pipe once and saw the same Bolt / Washer set up, and it works! :2thumbs:
I posted this recently somewhere on here. It's popular and listed on the nightrider website.
lee
I think I'll give it a try - will I have to mess with the carb after doing that?
go4dave
this looks like a very good idea.. and i know, that back pressure is needed to build the most torque. What is the distance from the exhaust port,, to the "modified" baffle? Is there a proper distance, then variables to that?? Both cylinders should be the same (i lean towards yes)?
lee
Probably impossible to say cus it will depend on your particular set up / exhaust diameter etc - it says to put them in near the end - you could also put the power cones in to help stop the exhaust gases getting back in through the port although I think our cylinders might have a step in the port to help with this
lee
who ever gave me a rep point I thank you for it - I wasn't expecting one of those for at least a couple of years!
Click "Quick Links" then "User CP"... it might have been me... I don't remember so i'll rep ya just for shits
